clear ports link-flap-detection counters
clear ports [port_list | all] link-flap-detection counters
Description
Clears the counters related to port link-flapping.
Syntax Description
ports Physical ports.
port_list List of ports that you want to clear the link flap counters on.
all Selects all ports in the system to have their link-flap counters cleared.
counters Counters related to link flapping.
Default
N/A
The following example clears the link flap counters for ports 4 through 12:
clear ports 4-12 link-flap-detection counters
This command was first available in ExtremeXOS 22.1.
Platform Availability
